Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Railing
    Raymore Missouri
    1,907
    Default Railing
    Here's a little job I did the other day. 2" square posts with cast iron caps, 1/2" solid pickets, Punched top and bottom channel which I do, and mould cap for top rail. I primed and customer will paint in spring.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Default railing
    Nice work looks pretty solid to
    ARMOR
    MOBILE WELDING&SERVICES
    Trailblazer 302
    X-TREME 12VS
    Spoolmatic 30A
    Millermatic 135
    WeldCraft WPseries TIG torch
    Smith oxy set.
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    Thumbs up
    I have to say looks good. As armor said, very solid.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Raymore Missouri
    1,907
    I hate wiggly rails. I like the solid feel
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    1,569
    Looks nice. What kind of anchors did you use?
    Raymore Missouri
    1,907
    5/16 " wedge anchors. I think that's what they call them. 7/16 nut. Drill a hole, tap them in and tighten. I like them
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Jul 2010
    Salem, NJ
    262
    Nice job. How old was that concrete? Aweful brave to be drilling that close to corners with a hammer drill.
    I stopped building rails a few years ago when codes and insurance is getting ridiculous. Does your state require 6" sphere rule for the steps? Just saying because there are railing chaser lawyers also, just like ambulance chasers.
    Edit: that is a REALLY nice picket twister you got. I wish mine had a hand wheel like that. You'll have to show me a few pictures of it.
    Jan 2013
    25
    Looks nice, straight, and square which is always a challenge for a straight picket railing,that railing will last for many years ,assuming the concrete holds up.
    561
    Default Railing
    Looks like a clean job. I agree with risky drilling on the corner of steps. Only problem with using tubing and a top channel is they always rust from the inside out, reducing the service life. My preference is to use solid 1" bar for posts and welding the pickets directly to the under side of the molded top. I assume that's what the customer wanted, can't argue with the customer!
    Raymore Missouri
    1,907
    The top mould cap sits on the top channel which is 1" x1/2" inverted with legs up... before the mould cap is welded on,,,the channel and cap is primed. :The concrete is only a few months old. Easy to drill. I keep my picket spacing less than 4 " on all sections. My railing is nice and plumb but I have no idea what that mass of concrete will do if it should settle off kilter.BTW...all welds on pickets are inside c channel and will not be seen. Much cleaner look.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
