Thread: Alum. project
    Dec 2011
    Illinois
    87
    Default Alum. project
    Ok guys, the father inlaw has made a smaller version radial engine all aluminum its a work of art to say the least. He made every single piece right down to the push rods and spark plugs. Anyway he has asked if I can make him a stand to display it at shows.
    Basicaly he is looking for an L shaped type stand made from 1/4 " aluminum 12" wide 13 " tall 18 " for the base so this is his request. My question is this, I will be welding this with my diversion 180 ( Im aware it's maxed out at 3/16) but with a little pre heat I think I will be ok being that im not going to run a full bead on this this thing, probably a few 2" beads or so on both sides. should I taper the top piecs coming down to join the base for the ease of welding? thinking of clamping a piece of angle to help prevent things for moving around.If you guys got any input or ideas to help in this project please feel free to chime in thanks, Eric
    Aug 2010
    1,170
    If you are able to pickup a small bottle of 75/25 argon helium mix, it would greatly increase the weldability of that angle. Along with preheat you are good to go.
    Good Luck and have fun.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Dec 2011
    Illinois
    87
    I agree however all the lws around me are saying the helium is hard to come by these days. do ya think beveling the verticle pieces edge where it meets the base would help some? Im thinking warpage should not be a problem with the approach im takeing , no? Thanks for the help in advance, Eric
    561
    I would bevel both the base and the vertical peace 2" from each end. Clamp the angle in the middle, not Behind where you are welding, that way you don't draw the heat away from the joint.
    Dec 2011
    Illinois
    87
    Thanks for the input fellas, probably going to get going on it in the next day or to after i finish current project, just figured would get some outside input before hand thanks again, Eric
