So, welding the exhaust system is better in trucks than using band clamps. welded tubing is stronger and durable. But what are the chances of having holes in the exhaust system?
Results 1 to 10 of 11
Thread: Welding vs clamps
01-20-2013, 07:59 AM #1
- Jan 2013
- 1
Welding vs clamps
01-20-2013, 09:17 AM #2
Welding vs clamps
I have not heard that before. What kind of trucks are you talking about? I have never seen exhaust welded on big trucks (class six and higher) the band clamps hold just fine. I personally do not weld unless other options couldn't accommodate.
Never Satisfied
Millermatic 211
Maxstar 150STL
Metabos
Kennedy Maintenance Pro Full
Makita Cordless 18v Li-Ion
Stihl TS 420
Timfrank88@live.com
01-20-2013, 11:43 AM #3
- Nov 2012
- Northern Arizona
- 268
My jeep is welded together. That is a good thing because with my little 35" tire the exhaust takes a beating. I would have surely ripped the clamps apart by now. Now my 3/4 ton pickup it just clamped together. different application. It works great. I haven't had any issues from the turbo to the exhaust tip. Also, it is easy to change, modify or replace in my driveway.
So, moral of the story: application is important. If you can weld, you won't have holes in your exhaust. If your a hack welder, well then that is a completely different story...MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
01-20-2013, 01:21 PM #4
Clamps are better for several reasons. They're engineered for this use, so they're not going to break. Welding can make the tube weak &/or brittle. It's also difficult to weld all the way around, which is why you see stuff like this so often:
Clamps don't damage the pipe (except cheapo U-bolt clamps), so they can be easily serviced/repaired/replaced. And good clamps are reusable indefinitely. Do you want to carry a cutting torch & welding machine when you go wheeling? You can certainly carry a ratchet & sockets. Lastly: clamps allow for some flex, and that's GONNA happen. Even if you weren't talking about a beater Jeep, it still happens just from 15' of steel going from -10F to 300F.
But an even-better solution is welded flanges. Best of both worlds - the security of welds, with the ease of bolts.
...and they're CHEAP!Walk softly & carry a BIG SIX ! ! !
MM211 + SM100
01-20-2013, 01:38 PM #5
- Nov 2012
- Northern Arizona
- 268
Funny you should ask, I keep a tb302 and 625 extreme in the jeep when I'm wheeling... NOT
A broken off muffler isn't exactly on the top of my concerned list when I'm out beating on my jeep. I really break something some jumper cables and a few rods and I can weld something back together. For my used welding my exhaust together works just fine. I wouldn't want to deal with it on a vehicle that sees different use. I don't have much exhaust to mess up on my jeep anyways...
Flanges can be a great option too if they are installed right.MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
01-20-2013, 02:04 PM #6
- Feb 2012
- Wa
- 316
I was thinking flanges too. You ever see v band flanges?
01-20-2013, 04:59 PM #7
01-20-2013, 05:56 PM #8
- Feb 2012
- Wa
- 316
01-21-2013, 05:52 PM #9
- Sep 2005
- 4,246
There is a place for welded, many repais done this way and welded is often used when pieces want to rotate, just cant come loose like a clamp.
01-21-2013, 06:16 PM #10
It's one of things where you can do it how ever you want, ain't gonna be a big deal.
I'd rather spend my extra time drinking beer than arguing over something like this
🍻🍻Ed Conley
