Maybe its common, and an easy fix (so I hope). I have a blue star 185, that runs great. Problem is that it welds wide open (180+ amps) all of the time. It will not adjust. I have tested the rheostat and it seems to check out fine. Should I just replace it? Any one have any ideas? Can I get one from an appliance store, or does it have to be from miller? Has anyone else had this problem? I'll post serial # when I get home tomorrow.
Results 1 to 5 of 5
Thread: Bluestar 185, amps wont adjust
01-19-2013, 09:57 PM #1
Member
- Feb 2012
- 43
Last edited by aaronobrien; 01-21-2013 at 06:50 AM. Reason: not a 185... Miller Bluestar 6000
01-21-2013, 06:41 AM #2
Member
- Feb 2012
- 43
So... I actually have (2) of these machines with the same problem. And actually, they are not 185's. They are both Bluestar 6000 machines.
#1 serial# LE130118 stock# 903585
#2 serial# LC533392 stock# 903584
Any and all help would be appreciated.Last edited by aaronobrien; 01-21-2013 at 06:48 AM. Reason: Added info
01-25-2013, 07:27 PM #3
Member
- Feb 2012
- 43
I'm gonna try replacing the pc1 board this coming week.
02-08-2013, 06:56 PM #4
Member
- Feb 2012
- 43
Well, if anyone is following this, the problem ended up being the pc1 board. Miller wanted $4xx for a new board. I could get one from y supplier for $3xx. I found a guy in Miami that rebuilds them, he rebuilt it for $150!!!!! Got it back today, welder fired right up, and adjusted perfectly. All is well again. Im gonna send him the board for the other machine next week. PROBLEM SOLVED!!!!!
02-09-2013, 02:52 PM #5
Miller gives you the suggested retail price and will not sell to anyone but distributor. That's why when you bought it from the distributor it was cheaper.
