    1,883
    Default Small steel rack
    Here is a small steel rack I built for my shop since my other one is full. Used 1.5" X 1.5" angle. I made a couple ladder type ends connected with an x brace on the back. Openings are 7" x 7". Then I added a couple extra pcs. to make extra openings which are now 3.5" x 7"w. I was going to tie it into the wall but it is surprisingly stable so it stands alone.1130021304.jpg1130021541.jpg
    Jun 2009
    greenfield new hampshire
    881
    looks to be very helpful, keeps stuff off of the floor, i usually make my racks free standing also, i do mine a little differently, well, the last one was different, i make 2, tripods, looking like the 3 legs of a telescope, or transit, ect, place then apart about 6-8 feet. tie the top and bottom together to hold its width, then weld short pieces on the 2 vertical legs to hold the steel, it works well cuz it can be loaded on both sides, sorry for no pics, i do like your design, it takes up minimal wall space.
    Illinois
    612
    Cool ! You never have enough storage. I made a small 4 shelf unit for all those short pieces that were in 5 gallon buckets and drums. I should have done it 20 years ago. Just never had the time. Keep up the good work.
    I really expected to see I beam bases with 3'' pipe risers and arms coming
    off like a christmas tree.
    1,883
    I only had 12" between the wall & the gantry. Mostly I just had stuff piled there until this design popped into my head. So simple but never thought of it before.
    The other rack I have is more traditional. Tied into a wall with arms coming off but it was overflowing.
    Jul 2010
    Salem, NJ
    280
    I had a rack like this in my first shop... They fill way too fast!
    Nice work
