Results 1 to 4 of 4
    Default Rated Output vs Welding Amperage Range
    My Miller 211 has the following specs:
    Rated Output
    150 Amps at 23.5 VDC, 30% duty cycle (230 V)
    30 - 210 Amps
    Before looking at this in detail I would have thought these two values would have been the same on the top end.
    Can someone explain these for me? Thanks.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Feb 2010
    YOUNGSTOWN, OHIO
    128
    Rated outputs are your typical everyday use. You could get the 210 amps out of it, but your duty cycle will drop to 10% or below.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Thanks Jim. I figured it was something like that but couldn't put it in words. :-)
    Miller 211 MVP
    Lincoln AC 225
    CutMaster 42
    Feb 2010
    YOUNGSTOWN, OHIO
    128
    No problem. Glad to help.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
