    Mar 2011
    torrington, connecticut
    22
    Default 304 cc/cv welder
    gentlemen, a little help please. have a 304 cc/cv miller that started showing help 5, machine welds fine, shows help 5, shuts down. fan does not come on before or after shutdown. s/n lb075651. took covers off to check for excessive dirt, etc.-looked pretty normal (blew it out anyway). reassembled, no change in function. suggestions? thank you.
    6,752
    Well change your fan out, takes 15 minutes once you have a new one in your hands
    Mar 2011
    22
    Default xmt
    thanks cruiser, will test feed to fan motor to see if its getting power. what voltage should i expect to see at the fan motor? thanks.
    6,752
    24vDC
    Mar 2011
    22
    24vDC
    thank you
