Results 1 to 7 of 7
    Exclamation HELP! I think i killed it. AEAD-200LE ( Updates for Cruizer )
    I borrowed a friends legend aead 200 le to do some repairs on an excavator bucket. While running some rather large hard facing rods the arc became very weak, and started stuttering.
    So I switched to an 1/8 rod same result.
    And I could have sworn I heard something snap when it went out, but hard to tell under the helmet.
    I was definitely leaning too hard on the welder when this happened,
    I need to get this fixed.Where to look first?
    Serial # JJ479736
    Jan 2012
    Metro Detroit, MI
    185
    Default HELP! I think i killed it. AEAD-200LE
    Find a new friend. Sorry I am not welder repair savvy. Does it idle up and down at all?
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    8,230
    Well, it sounds like one or more of your diodes in the rectifier pack is pooched
    Thanks cruizer, Ill hunt them down and check them out. Not sure of testing procedure though. I have a hand held multi-meter not sure that would test a diode.
    Jan 2013
    5
    That multimeter will work as long as you can check ohms. U will only get continuity one way through it.
    Cruizer, is this the rectifier? It is pooched.
    Is this SR1 on the schematic for this machine?
    *UPDATE*
    I have located and ordered a new rectifier, that being said I am wondering what caused this?
    I did clean the rings and inspect the brushes, two were stuck in the holders.
    8,230
    Age and use causes it, likely 1 or more puck dides were trashed, then one by one the rest are over loaded.
