Results 1 to 6 of 6
    May 2007
    Los Angeles
    116
    Default Spectrum 625 xtreme fan noise
    I just bought a Miller spectrum 625 xtreme and i noticed that when i go to shut off the unit the cooling fan kicks in and goes to what it seems like full RPM for a second or two before it shuts off. It will do this even if i turn the unit on and then off again without even cutting anything. Is this normal?
    Nov 2012
    Northern Arizona
    268
    I think it is. Same behavior on my cst280 stick machine. Heck, If forget to power it off and the unplug it the fan will crank on for a couple seconds. I've also seen this with a 875 plasma.
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
    May 2012
    21
    My 875 does the samething. They told me that is normal. I have had this machine going on almost two years and it is awsome. Ask cruzier first he knows his s#%t.good luck
    Jun 2012
    Tracy, CA
    175
    Yes. I have the 625. It's always done it. Even if I just turn it on and off again without using it. It also does it if I unplug it from the wall without turning the power switch off first.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Millermatic® 211 Auto-Set™ w/MVP™
    Spoolmate™ 100 Series
    Diversion™ 180
    Spectrum® 625 X-TREME™
    May 2007
    Los Angeles
    116
    thanks guys.
    Aug 2011
    Appleton Wisconsin
    35
    The fan turning on is normal. The unit uses the fan to bleed off the voltage stored on the bus capacitors.
    Tim Lux
    Service and Aplications Specialist
    Miller Electric Mfg. Co
