Results 1 to 6 of 6
    Jan 2013
    4
    Default Dynasty 200DX no amperage control.
    I have no amperage control via foot or hand controllers. I've even used a known good miller foot control and no dice. Unit works fine when RMT2T Hold is selected but not when RMT STD is selected. I can start an arc with whatever max amp. dialed in but the amperage doesn't deviate from start amperage.
    Any ideas out there? Pedal is set up with pins A-E. Do I need one or more of the other pins to use a standard tig torch on this?
    Feb 2012
    561
    Have you done a reset?
    Jan 2013
    4
    Did the factory settings reset.
    Jan 2013
    4
    Any ideas on where to start looking for the issue? Are there fuses inside that go to the remote? Also, is it normal for this welder to make rectifying noise, buzzing, when powered up and not welding?
    Jul 2010
    Salem, NJ
    262
    Have you ever welded with this machine before with a foot control?
    Also, the humming noise is normal.
    Jan 2013
    4
    Honestly I don't remember. I think we have but it's been stored away for several years.
