Hey I'm wondering what an acceptable standard is for dye testing welds. Everything I've researched shows that you spray the dye on the weld to check for surface cracks. However is it acceptable or up to aws or asme code to dye the backside of the weld and spray the developer on the weld itself to see if the dye bleeds through the piece?
Results 1 to 8 of 8
Thread: dye pen
01-11-2013, 04:49 AM #1
- Jan 2013
- 14
dye pen
01-11-2013, 09:45 AM #2
Member
- Nov 2011
- Edmonton
- 35
dye pen
You spray the dye onto the weld- let sit 10 minutes- wipe off really well then spray the developer on and wait 10-15 minutes and look for the dye to show up on the white developer. Never seen it done the other way though..
01-11-2013, 01:44 PM #3
- Apr 2009
- 358
01-11-2013, 02:58 PM #4
- Feb 2004
- 1,160
Some days you eat the bear. And some days the bear eats you.
01-12-2013, 08:15 AM #5
- Jan 2013
- 14
dye pen
Ok thanks guys. The answers you gave me back up what I've researched.
01-12-2013, 08:18 AM #6
- Jan 2013
- 14
miller ac
Hey I'm considering buying one of the ac packs for your welding hood off the miller site. Does anyone know if they are worth the 300 bucks?
01-15-2013, 01:07 PM #7
when we check tanks we will spray dye on the inside and developer on the outside (leave for a few hours before checking). this does not meet any codes but will tell you if there is a leak and will hold fluid. this is done buy many companies to check tanks and also worked with some companies that fog dye inside and test the out side to pass for the API certs. so yes this will work to look for leaks in a tank. if you are looking for cracks in the weld zone then use as described on the can.
trail blazer 302
hypertherm plasma
millermatic 251
high feq. arc starter
suit case (extreme 12vs)
o/a torches
01-15-2013, 01:16 PM #8
- Jan 2012
- Marsden, sk. Canada
- 27
if coating/painting is not an issue you can also use diesel pen. it is an acceptable test on large storage tanks for the floor to shell weld
