    Jan 2013
    18
    Default Hole punching machines.
    Hi, I'm struggling to find a machine/press to punch 25mm/1 inch holes at 8 inch intervals. The steel is 50mm box steel for power racks. I've been drilling them by hand but its very time consuming.
    Aug 2004
    Milan Michigan
    1,418
    Get a drill press, Punching will only crush the tube unless you have some very special machinery, The average iron worker cannot punch tube.
    3,655
    Hole saw and a drill press...Bob
    Nov 2010
    256
    High speed milling bit and machine works great too.
    Oct 2012
    yuba city, CA
    24
    Default hougen roto broach
    If the tube wall thickness is 3/8" (10mm) or less, the Hougen 1" roto broach on mandrel, SLOWest SPEED WITH CUTTING OIL in drill press ( as sold in their electrician's kit) will be faster, more accurate and outlast a twist drill or hole saw--every time. You can buy the mandrel and the cutter separately from distributors.
    These are the shallow depth roto broaches--not the full size, mag drill broaches.
    I've used hougen cutters extensively for 22 years.
    The reason some pro shops don't use them is, of course, that they're too cost effective.
    Aug 2012
    Hermiston Oregon
    122
    Use a mag drill. And jig it up.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Jan 2013
    18
    Guys thanks very much, I'm going to use every method I can afford! Thank you again.
    Apr 2008
    dallas,tx
    204
    Miller 350P
    Miller Econotig
    Milwaukee Dry saw
    Evolution Dry saw (for sale)
    Scotchman 350 cold saw
    7x12 bandsaw
    1910 ATW 14 x 72 lathe
    fridge full of adult beverages
    Sirius radio
    www.snpequipment.com
    callouses and burns a plenty
    Aug 2008
    103
    i would love to see a video of how that death trap works
