Results 1 to 3 of 3
    Jan 2013
    Default miller 175 keeps burnig wide open on its own
    first i new to this site so im gonna say what up.
    now for the problem. i have a miller 175 that has a tendacy to just decide to turn the voltage wide open when it wants to at times. usually when im welding something thin like body panels and stuff. when i weld something thicker i cant really tell the difference but it does do it at times. i am wondering if it is the voltage rheostat on the machine thats shorting out. im kinda curious if this is a common problem or if someone else had this same problem. i would say the machine is about 10 years old.
    Jan 2013
    3
    I have a Miller tig welder that had the same problem. It turned out that a relay inside was worn out. Actually the points on the relay would stick closed because they were arcing. I was able to take the relay apart, sand the points and get it working again. Eventually the relay had to be replaced.
    Appleton, WI
    406
    The voltage control pot on the Millermatic 175 is a 50K ohm, I would definately start there for t-shooting it.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
