Results 1 to 2 of 2
    Jan 2013
    Ohio
    57
    Default passport plus not feeding wire
    My new passport isn't feeding the wire...the wire wheel doesn't turn or the wire feeder wheel doesn't turn either... When I press the mig gun trigger I hear a beep and click but nothing moves...any tips or troubleshooting ideas are welcome...went through manual and everything is hooked up right...please help...thanks
    Jan 2008
    328
    Default Is it switched to spoolgun?
    Make sure the machine is set up to run the gun and not a spool gun. spool gun setting on Hobarts turn the drive motor off. Not sure of the passport.
