Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Tool Chest Cart
    Sep 2007
    Medford MA
    525
    Quote Originally Posted by the-apprentice View Post
    MMW, anything I should be careful about? lots of bracing I would think. I do not plan on doing any drilling, mainly just using abrasive cut off disks to cut it, then just weld it up.
    Are you planning to weld the casters to the structure? If so, what if they need to be replaced for some reason?
    Btw, spend the extra money so that all four casters are swivelling and locking. It makes it a lot easier to roll the thing into a tight corner, etc.
    Frank
    Jan 2013
    Calgary, AB
    7
    MMW, thats exactly what I was thinking.
    fjk, at first I thought about welding them on, but I may do height adjustable for uneven floors. I am for sure using all 4 swivel, not sure about lock yet.
    Jan 2013
    Calgary, AB
    7
    Default Update!
    I just did a rather large post with a bunch of pictures over on Hobart's Weld Talk.
    Here is the link to check it out!
    http://www.hobartwelders.com/weldtal...769#post430769
  4. #14
    Feb 2012
    wisconsin
    113
    Looks like it worked out fine. Grinding sparks flying towards cardboard is never a good idea.
  5. #15
    Jan 2013
    Calgary, AB
    7
    Thanks! yeah I know, thats why I keep four fire extinguishers around!
  6. #16
    northern NJ
    1,569
    Looks good. You should look into getting at least a welding curtain to stop most of the sparks or clean out a lot of the flammables. Where's the middle shelves?
    MM250
    RCCS-14
  7. #17
    Jan 2013
    Calgary, AB
    7
    Yeah I probably will, just not enough time or money recently. I have yet to put the middle shelf in, however when we cut the bed frame apart, we cut the four uppers out of the same frame and they have slots at the exact same height, so no drilling required! I will probably just use some 1/2" plywood seeing as I have tons of that around.
Tags for this Thread
