Results 1 to 10 of 17
Thread: Tool Chest Cart
    Jan 2013
    Calgary, AB
    7
    Question Tool Chest Cart
    This christmas I was lucky enough to receive a new tool chest for christmas! The tool chest is a Mastercraft Maximum 5 drawer tool chest (http://www.canadiantire.ca/AST/brows....jsp?locale=en) and I am planning on building a rolling cart to hold it, plus more tool storage on shelves underneath. I am planning on constructing it with some angle iron I salvaged from some old bed frames and welding it up with either some 6011 or the cheap 7018 AC I have.
    Hopefully I will get to building this in the next couple weeks during exam break. If you guys have any thoughts or input it would be greatly appreciated!
    Sep 2007
    Medford MA
    542
    Bed frames are generally not "plain old carbon steel".
    If I recall, they are high carbon ... But don't quote me on it
    I suggest you search this board, there have been some good discussions on it
    Good luck and post pictures when you build it!
    Frank
    Mar 2011
    st-eustache qc.canada
    244
    FJK is right! bed frames are good only at waht they are made for.
    They are much more stiffer than angle but they are also very brittle...
    Scrap them before someone use them at a critical application where failure will occur . Not even good for a picket as they micht break when hammered.
    good luck, have fun.
    May 2011
    Bossier Parish La.
    560
    Quote Originally Posted by snowbird View Post
    It appears that he IS using them for a non-critical application here. It's just a cart for a tool chest. Not likely going to cause any fatalities if it fails as long as he's not towing it down the highway.
    Take some pix of the build as you go and some of the finished project.
    May 2012
    15
    Oh jeez.... just step back son and think for a minute of all the people that will be killed, if you use re-purposed, old bed angle iron material for a toolbox holder/cart. The stresses and dangers involved on such a contraption is mindboggling. Oh the humanity........
    There will always be naysayers, no matter what you do. He has a 5-drawer topbox, hes not building a 10 ton Gantry crane. Go ahead and make it, and wallow in the pride that you built it yourself.
    Miller Dialarc 250 HF Tig with Miller Coolmate 4 water cooler
    MillerMatic 250 (Co2 .035)
    MillerMatic 130 (Co2 .023)
    Miller Spectrum 375 Plas
    Fronius MagicWave 3000 Comfort tig with integrated watercooler.
    Century AC 250 stick welder (my first welder...and still have it)
    Jan 2013
    Calgary, AB
    7
    Thanks for all the input, I have thought about the steel not being the best to work with, but I am going to do a couple test cuts and welds with it before I jump into the project. Dirt Farmer nailed it right on the head, it is not something that has to be excessively strong, if it does break I may get a dent in my box, but oh well. I do not plan on attaching to chest to the cart, so it will be in two pieces for transport and I will set it up where ever I am using it.
    I plan on taking many pictures and documenting it as well as I can!
    northern NJ
    1,914
    The design will have more to do with a failure than the material itself. Go ahead & use it. Weld it with whatever you got.
    MM250
    RCCS-14
    Sep 2007
    Medford MA
    542
    Agree with the others that you're probably ok to use it for this application.
    Just search the board for hints on welding it, it's not normal.
    Also, it's hard to drill, cut, machine, etc. again, search the board for hints, etc
    Good luck
    Frank
    Jan 2013
    Calgary, AB
    7
    MMW, anything I should be careful about? lots of bracing I would think. I do not plan on doing any drilling, mainly just using abrasive cut off disks to cut it, then just weld it up.
    northern NJ
    1,914
    Assuming your going to make it like the outline of the roller cabinet you will be fine. Several picture frame looking pcs. out of angle for bottom, top & a few shelves. All attached together with four uprights, one in each corner that go from top to bottom. Weld it all up & you'll be good.
    If your really worried about it add some x braces on sides & back that go from corner to corner but most likely not needed.
    MM250
    RCCS-14
Tags for this Thread
