    Default Cutting and welding Dexter torsion axle?
    I just baught a dexter 3500# torsion axle from a friend. I want to use it for a smoker trailer, but the axle is too long. Can i cut and shorten the axle? I did read a few articles saying the rubber does not run the whole length of the axle, just from each end in a few feet. This axle is made for a 80" frame. The smoker tank is 30" wide and I want to keep the tank close as possible to center. So at 60" I would have 15" on each side from smoker tank to side of trailer. This way I can reach the doors. I dont even know is I can take 20" out of the axle.? any help is appreciated. Thanks, Joe
    Jan 2013
    Valley City ,Ohio
    I never cut that type of axle although I was at a scrap yard and saw an axle that was cut on the one end and the rubber was hanging out about 10 inches. It had caught my eye because I never seen that type of axle before. Good luck.
    1,569
    Having never cut one of these apart myself I would proceed like this. Mark out where you want to cut. I'm assuming you want to take a section out of the center? Drill a hole where your cut line is & see/probe if there is anything there. If not cut away. If there is then just plug weld the hole & sell it off.
    If you do cut it, I would put an internal sleeve at the joint for strength. Just remember that trailer axles are usually cambered slightly.
    Aug 2012
    Hermiston Oregon
    122
    I've done what you are wanting. Except I made mine wider. The rubber only extents 12" -16" into the square tube. I cut at the center. Grew the width and reinforced the tube. Make sure that you weld in sections to keep the heat at a minimum. And away from the torsion rubbers.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
