hello all,
thanks in advance for any help you might be able to provide. I'm a newbie and found this forum.
I have a Syncrowave 180SD older model, but very little usage and worked fine for all my small welding a few years ago. It's been stored in our normal garage.
setup: max 60 amps, "tig", negative electrode. argon set to 18lb flow, tungsten is 1/16" 2% thoriaded "red" Ground is clamped to the top of the welding table which is a steel/stainless steel type cart that I've welded on before (all of my welding)
I'm welding a typical 2" 304 stainless exhaust pipe to a header type flange.
I tap the peddle away from the machine for the post flow. Bring the tip to my work piece and almost instantly when I touch the peddle to start the weld, it will burn a hole immediately through the work. With so few settinges on the machine, I can't imagine anything, but that there's an issue with the machine.
Anyone have anything else i can check? or insight into what might be wrong?
Results 1 to 3 of 3
01-12-2013, 05:29 PM #1
- Jan 2013
- 1
180SD burning a hole through my work with just a peddle tip-in
01-13-2013, 04:58 AM #2
Sorry I don't know the exact cause but it seems to happen on these machines. If I remember correctly it is a board issue that gives you max output only. Try a search on here for some more info.
01-18-2013, 11:30 PM #3
- Jul 2010
- 9
Same machine, same problem. It's likely the connection to the hall effect sensor. Remove the cover and locate the sensor on the top (has a bus bar through it). remove and re-plug the 4 wire connector and try again. This worked for me but now nothing works. Could be any of the connectors too. I haven't used dielectric grease yet but I plan to first before replacing the sensor. If all else fails, swap out the sensor (19141 - $53 at Miller4less). Let me know what happens please.
