Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Nov 2009
    Ohio
    118
    Just wondered. The Lincoln 175 we have at work has it & you have to turn it manually to your selection & if this Diversion welds anything like that Lincoln 175 we have I will say it will be a nice addition
    Miller Trailblazer 302
    Miller Passport Plus
    Miller Spoolmate 100
    Milwaukee 4 1/2" Angle Grinder
    Milwaukee Sawzall
    Miller Elite Inferno Hood
    Miller Diversion 180
    Miller Digital Elite Vintage Hood
    Miller Camo Digital Elite Hood
    The Diversion 165 has material thickness for steel and aluminum as secondary scales to the amperage. The 180 has a chart for steel and aluminum thickness and amperage. With either machine you can select an amperage for the material type and thickness just by looking at the front of the machine and setting your amperage.
    Feb 2012
    561
    Default Opinions on Diversion 180
    This is a tig only welder. I was under the impression that the Lincoln 175 was tig and stick. I can see the use for DC+ , with a tig and stick welder
  4. #14
    Aug 2010
    Los Angeles
    1,099
    The Diversion is purely entry level, and brilliantly done. Like the transformer tigs of old, your choices are very limited, and for good reason. Kind of like a tig welder on training wheels. Professionals would call them boring. I am quite fascinated by them myself. Of course I would killify it straight forward(under warranty of course).
    If you are proficient in tig welding I would not recommend a Diversion. The Dynastys are pretty amazing in the hands of someone who knows how to use it.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
  5. #15
    Nov 2009
    Ohio
    118
    You can stick weld with the Lincoln 175. But with the Diversion 180 you can use 110 or 220 but you cant stick weld with it.
    Milwaukee Sawzall
