Results 1 to 10 of 15
    Nov 2009
    Ohio
    118
    Default Opinions on Diversion 180
    Looking at getting one of these machines. I just wanted to see what those of you that have one think about it. Anybody upgrade the torch or work lead? I see its rated for 3/16" but is 1/4" possible? I know on my Passport it was rated 3/8" but felt it ran pretty hot on 3/8" & half inch has never been a problem with it. Didnt know if the Diversion 180 is underrated? Any info will be awesome as Im hoping to get this very soon.
    Miller Trailblazer 302
    Miller Passport Plus
    Miller Spoolmate 100
    Milwaukee 4 1/2" Angle Grinder
    Milwaukee Sawzall
    Miller Elite Inferno Hood
    Miller Diversion 180
    Miller Digital Elite Vintage Hood
    Miller Camo Digital Elite Hood
    Oct 2006
    Illinois
    650
    I would add a few hundred and go for the 200 syncro.
    Nov 2009
    Ohio
    118
    Already have one out at the farm. Like the versatility of the 110 or 220. Really just wanted some opinions on the Diversion 180. Thanks for reply though.
    Milwaukee Sawzall
    I mostly work on 1/8 aluminum but wish I had the syncro instead.
    Mar 2011
    La
    318
    I wish I would have waited, learned more and saved more. Would like to have a dynasty 200 dx.
    Dynasty 200 DX
    Millermatic 350P
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution dry saw
    40 ton press brake
    Evenheat Heat treat oven
    1x42 / 4x48 belt grinder
    The Diversion delivers on all it promises. If you are new to TIG it will get you started with everything pre-set except the amperage. As you get a handle on the process you may find that you would like to be able to adjust some of the other parameters and be able to pulse.
    If you have used a full function machine and know that you won't miss that adjust-ability the Diversion is great.
    there are fully adjustable TIG machines in the same price range as the Diversion available form Thermal Arc, Everlast, and others.
    For what it is the Diversion is great. If it is what you want and need it will be a good machine for you.
    Nov 2009
    Ohio
    118
    So is there a dc- & dc+ to choose from or is it always dc- or ac? Also I was wondering about the front panel. Is that just like a chart on a mig welder to use for reference on what to set the welder at? I dont have a very good pic of the machine & haven't seen one in person. Only access to the internet is my phone. If someone has a good clean pic of the front could they post it please.
    Milwaukee Sawzall
    Aug 2010
    Los Angeles
    1,179
    Quote Originally Posted by J C View Post
    The Diversion is only DC- and AC. As far as a panel chart, the front panel is self explanatory and straight forward, so a chart would be redundant.
    Duty cycle is limited, but with the addition of helium to your cover gas, you could weld 1/4".
    If you have not had a look at the manual, do so. It shows how easy to setup.
    Go to section 5(operation), page 20.
    http://www.millerwelds.com/om/o246522g_mil.pdf
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Nov 2009
    Ohio
    118
    Thanks for the info shovelon. I was asking if the front panel is a chart. Dont need a chart just curious what was on the front
    Milwaukee Sawzall
    Feb 2012
    561
    Why would you want DC+?
