Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
    Nov 2011
    164
    Default garage Elevator Man lift project
    I would like to build a man lift/elevator with a 1000lbs capacity.
    I have been looking for a used palette lift but haven't seen one locally for over a year. Shipping is cost prohibitive.
    The attic opening is 4x6' and the total lift height needs to be 9'
    The platform should also fold to save space when not in use.
    I was thinking of hydraulic or worm gear type or even a winch with pulleys.
    Open to suggestions!
    What size/type and thickness of steel should I use?
    Eric
    Anytime a post starts with:
    "I'd like to build a XXXX".
    And ends with:
    "What style/type and thickness of steel".
    You know this, the poster has no buisness building "XXXX". Either get someone else to do the job, or educate yourself to the point that you don't have to ask kindergarden level questions. That way nobody will likely get hurt. At your present level of understanding you are a disaster just a waiting to happen.
    Or buy a used scissor lift.
    Either way you need to gain a significant amount of knowledge before embarking, and asking what type of material isn't educating yourself. Price check liability insurance for the work you're contemplating and you'll have maybe an idea what might be involved.
    JT
    1,928
    JT is correct.
    Traer, IA
    317
    FYI - Most winches are not designed for a vertical pull/load holding. I Definately would not go that route....
    Nov 2011
    164
    "You know this, the poster has no buisness building "XXXX". Either get someone else to do the job, or educate yourself to the point that you don't have to ask kindergarden level questions"
    Thought I would ask the "experts"; if you don't know the answer no need to ridicule me a mere mortal.
    Liability insurance?? Will be used at home for my purposes by myself only. Oh yah I don't live in the USA where everybody is lawyered up and looking for an easy pay day.
    Would I build this for someone else or for money? No as I don't want someone using the lift above capacity or incorrectly and getting injured.
    I can build whatever I want at home and utilize it as I see fit and nobody can tell me otherwise including you!
    Thanks 4 nothing
    Traer, IA
    317
    Quote Originally Posted by ericher69 View Post
    Thanks 4 nothing
    1) Dont come to an AMERICAN website hosted by an AMERICAN company and bash AMERICA because it will get you no where fast.
    2) Wherever this will be installed, used by you and you only does not make it safe. You will not own that building forever - no one ever has and no one ever will. There is always the potential for someone else to get hurt because of someones stupidity.
    3) You build whatever you want at home and utilize it as you see fit - I have a feeling no one here will tell you any different on how to use it or build it.
    Nov 2011
    164
    1) If you can't tell the difference between Country bashing and hard facts ; http://www.sixwise.com/newsletters/06/10/05/how-many-lawsuits-are-there-in-the-us--amp-what-are-they-for-an-amazing-overview.htm
    Then I feel sorry for you
    2) you have a point and you are right
    3) Big loss! Lol
    Thanks 4 nothing
    Well I really do know the answer, but the fact that you asked it means you are in way over your head. And if you actually read my post, I didn't ridicule anyone.
    Of course you can, I never said otherwise, I suggested you educate yourself beforehand and I'll stand by that.
    You're welcome.
    JT
    Illinois
    661
    Might want to goggle ''homemade elevator.'' Pictures of the area would help including ceiling area. It sounds like you are asking a lot as far as folding goes.
    Might be cheaper to buy a gantry or copy one for what you require and use a electric chainfall. Your 1000 pound capacity may get used up quick depending on the platform construction. How much do you actually want to lift ? Can the attic hold the weight ??
    http://www.bing.com/search?q=Wallace...try&FORM=R5FD7
    Nov 2011
    164
    BD1;
    Thanks for the advice and link.
    I have a ballpark of 1000lbs to lift;
    This includes platform, myself (250lbs), blower, tiller, blade etc about 400lbs.
    Yes the attic has rough cut 2x8 joists 12" OC.
    Largest unsupported span is 15 feet.
    Will store heavy items over partition/supporting wall
