Results 1 to 7 of 7
    Oct 2006
    Illinois
    631
    Default MM 211 BEST wire size
    Ready to add the 211 to my collection. After searching the postings here and at other sites it seems that most did prefer .030 for steel up to 1/4.'' It was stated that this machine likes .030 better then .035.
    Just thought I would ask since this machine has been purchased by many here. Is there a wire manufacture that you like over others ? Lincoln, Hobart ??
    THANKS !
    Houston, TX
    900
    I would go over to Hobart Weld Talk and ask this question there. Dan is a regular contributor, has done field testing on many of the Hobart machines over the past years, and is an encyclopedia on welding wire.
    859
    Quote Originally Posted by cope View Post
    Alan (Cope),
    A MM 180 ( pre auto-set) is the only machine that Miller has ever sent me to test. I tried seeing if they'd send me a MM 211 to compare to the Handler 210 MVP. The replies I received back from the PM, made it seem like they were willing to send me a unit, however it never did happened. So, I'd be no help on providing feedback on a MM 211. I'd love to try one out though, because I am interested in checking out the Auto-set feature.
    northern NJ
    1,909
    I like the Hobart wire over Prostar which my LWS carries.
    Everything I have read says .030 unless doing body work then .023
    MM250
    RCCS-14
    Feb 2012
    Wa
    632
    I run .030 pinnacle alloys in my 180.
    Oct 2006
    Illinois
    631
    Thanks everyone, I did more reviews and 030 is what most guys prefer.
    Nov 2012
    21
    I don't weld on anything smaller than 16ga and I run .035 70s... Cheap Mailam wire for everyday use... Unless it's calling for a certain spec of wire in your process/print a good welder can take .80 cent/lb and make quality, and pretty welds. But you can sure tell when you put the high dollar stuff in, you don't have to "work" it as much it just flows like hot butter!
