    Jan 2013
    3
    Default millermatic auto feed
    Welding in auto feed (millermatic 211) mode wire started hitting the bottom. Worked fine in manual. Is this a sign of something going wrong? setting on .030 wire.
    2,971
    Hitting Bottom??
    May 2011
    Bossier Parish La.
    560
    Hitting Bottom??
    Sounds like the spool is running out of wire, install new spool of wire. I didn't know the MM211 had an Auto Feed mode. Do you means Auto Set? If so, go back to manual settings and forget the A/S mode. Most people that have these machines find out it don't work as advertised. Manual setting is the way to go with it.
    Jan 2013
    near Industry, Texas
    7
    That's for sure! The auto setting on my new MM211 is next to worthless. Waaaaaaaaay too hot on any but the thickest steel. Kind of irritating that they would develop (and charge) for a feature that is so far off from what's it is advertised to do for most people. Having said that, I'm having a lot of fun with it. Just wish I hadn't paid for a useless "bell and whistle".
    Apr 2011
    367
    Quote Originally Posted by the45er View Post
    You need to stop bashing a feature that you seem unable to comprehend. Auto-set works as advertised. You NEED to adjust it to your conditions just like any other machine. The idea is to get you in the ball park...no different than out of Auto-set, save for the fact that you have half the knobs to turn.
    Just For Home Projects.
