Results 1 to 8 of 8
    Nov 2012
    10
    Default can't make a stright weld
    got a nooby question here. just started stick welding at school, and i cannot make a stright weld to save my life LOL. i used soap stone to make a line, but it disappears when i start welding. is there another way so i can see the line?
    NY
    99
    Practice tying in stringers, and start on the edge of the plate. You may wanna try a lighter shade lens.
    Apr 2012
    Western Pa.
    335
    Soap stone works but u need to develop hand eye. To help that use two hands, one to hold stinger other to guide & keep steady. Also at 1st u can lay down a piece of metal as guide to slide your guide hand along. Make a dry run with hood up to get feel of bead then run it.
    As with most things practice refines, practice, practice, practice. It will come in time.
    Get old stinger or buy cheap one & put pencil in place of rod, practice in spare time on paper to develop skill.
    Dec 2008
    Arizona
    812
    Try grinding a shallow groove in the base metal to follow, it will be more like filling a seam than just trying to run a bead on flat stock.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Aug 2008
    113
    It Sure takes time and time and then more time
    Nov 2012
    10
    well i did a series of lines today, and they don't look to bad. i like to show you guys what i did to get some constructive criticism. how do you post pic on here?
    Melbourne, Australia
    107
    Also, don't be too proud to refuse using a cheater magnification lens.
    I use a 1.5 X most of the time and if the amps are really low I'll put on my reading glasses as well.
    Regards Andrew from Oz.
    We are tig welders, gravity doesn't worry us.
    Miller Dynasty 350 Tig.
    OTC AVP300 AC/DC 300 amp hybrid wave Tig. (now retired)
    Kemppi MLS 2300 230amp AC/DC Tig for home with all the bells and whistles.
    Sep 2012
    London
    21
    For doing straight welding, one need's a lot of practice. As everyone usually struggle with straight welding but after some practice one can do easily.
