I need a gas tank-Part Number 015670,
Machine S/N JG103842--1986 model
I called Miller and they want $535.28 with cap. What's wrong with that?
The tank is about 7.5" square on each end and is about 19" long.
Anybody got any good ideas?
Fred
Results 1 to 6 of 6
01-08-2013, 02:58 PM #1
- Jan 2013
- 2
Miller AEAD 200 LE-Oldie but Goodie
01-08-2013, 03:06 PM #2
- Feb 2009
- Lodi, CA
- 1,127
Supposedly you are a welder, just make your own gas tank.
What's wrong with that???????Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
01-08-2013, 04:30 PM #3
- Jan 2013
- 2
No, not a welder, a mechanic helping a welder fix his gear.
01-08-2013, 04:31 PM #4
- Jan 2008
- northern california
- 317
try smallengine warehouse
If you can use a simple rectangular tank look up generac generator parts on the smallenginewarehouse website. They often have new 4.5gallon steel tanks that include a cap. Often the outlet has metric threads so get a matching valve from them also.
Ornamental fabrication shop worker
at home...
2011 Hobart Handler 210
01-08-2013, 06:22 PM #5
- May 2011
- Bossier Parish La.
- 385
A gas tank and hose for an outboard motor will work too, it just needs to be installed above the level of the carbuerator. You could rig one temporary and then let the weldor fab up the tank he needs since you are not the weldor but mechanic. Or the weldor can fab up a support for the outboard tank to use it permanently.
01-09-2013, 07:46 AM #6
Member
- Oct 2007
- West GA
- 68
I have the some welder and the tank rusted out and I get a tank at northen tool for the north star stuff and mounted it to the top of it. And now have about 4 gals. of fuel
