Results 1 to 6 of 6
    Jan 2013
    5
    Default Trailblazer 302 TIG welding Aluminum Problem
    I have a Trailblazer 302 (model just before the 302 air pac) I am trying to TIG off off of it. I can TIG carbon steel great but when I go over to Aluminum on AC it just arcs a flaze with no heat and burns out the tungsten. Im using 2% thorated. Some one told me that I need a frequencey box but i thin this machine has it built in. Any suggestions?
    Mar 2006
    Corunna Ont, Canada
    449
    Default Alum weld
    Yes you need a way to stablize the arc...
    so you need a HF-251 high freq. box and some control cables and PURE tungsten(green band) pure argon.
    its works ok
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Mar 2006
    Corunna Ont, Canada
    449
    where are you located?
    I have a HF-251D for sale....
    Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Jun 2012
    Alberta
    57
    ^ what he said on his first post.
    Jan 2013
    5
    Default Thank you
    Im Near Charlotte NC Thanks for the help!
    Dec 2012
    2
    Hay Railmen what u want for that HF-251D
