Results 1 to 3 of 3
    Jan 2013
    Default More Econotig issues...., arc issues, no amperage control
    Hi, New to the forums here. Been reading everything I can on these econotig issues. Mine seems to be just a tad but different, or maybe not.
    First off I only use my machine for tig.. I replaced all torch components. Running I think the new purple tungsten. Airgas set me up with saying it will do alum/ and steel. regulator is at 20, tank is nearly full.
    I seem to have couple issues. My high freq works half the time, could be ground.
    It seems like it does not have enough oomph to even start a puddle, on 1/16-1/8" steel or aluminum. It barely has enough to melt the filler.
    Now If I crank it all the way up to 100% on the dial or all the way down the outcome is the same, not enough to start a puddle on steel. With my pedal I don't have any control either. Wide open or the very least the control does not differ. Like on or off.
    Thanks PRAXAIR wants $180 to send it out, + any more after that you won't know until you get the bill............ F-THAT !!
    6,763
    Sounds like your PC1 arc start board is pooched.
    Jan 2013
    I'm assuming this is the $300-400 board that I've been reading about?
    Dumb question but what would be the best course of action?
    Weird tho I seemed to be able to weld Or what I assume to be welding cuz I used some filler up, lol some 1/8th
    aluminum last night. Seemed like i had to move really really fast. But on some mild
    steel I can't get a puddle to start? DCEN is what I was on for steel
Tags for this Thread
