    1,919
    Default 306 stick electrode?
    I have several pounds of 3/32 rods that I got awhile ago unboxed. The only markings I see on them is 306. They are a light in color, almost white, with a green overcoat that is very lightly & unevenly applied. Kinda like sponged on if that makes sense. There is no rust or corrosion on the stinger end. I assume stainless but can't find any info anywhere. My Hobart book shows 308 as the lowest ss stick rod. Anybody have a clue as to what they are?
    Jan 2013
    Whitby / Ontario
    3
    Looks like it is an aircraft quality stainless, i have never used it before but it can be welded by all the regular welding processes except for oxy fuel
    Chemical composition % of the ladle analysis of grade AISI 306 and Standards
    C(%): ≤0.08
    Si(%): ≤1.00
    Mn(%): ≤2.00
    P(%)≤: 0.045
    S(%)≤: 0.03
    Cr(%): 18.0~20.0
    Ni(%): 9.00~11.0
    1,919
    After some more searching I found a hard facing electrode "Stellite 306". I still don't know for sure so I guess they'll just sit on the shelf some more.
    edit- the above stellite 306 are only tig rods.
    561
    http://www.mwa-international.com/index.php/products/47-hard-facing/138-mac-hard-e306.html
    1,919
    Quote Originally Posted by go2building View Post
    That seems to be the closest I've found. Thanks for finding it. Upon further looking the stellite rod I found is only a tig rod. I'll have to try these out on something that isn't critical.
