    Oct 2012
    14
    Default Regency 250 and Flux Core wire?
    Hello all, Got a question if i may. Ive got a Regency 250 PS and a Ex-treme 8vs feeder. And just by chance i noticed while looking through the owners manuals on the cover pages it says what processes that the unit is capable of, Well on the Regency's manual it only has GMAW and on the feeders it says both GMAW and FCAW. So my question is , Should i not switch the polarity on the Regency? Is it only for GMAW? Thanks .
    Oct 2012
    14
    bump
    Oct 2012
    14
    wow , nobody knows?
    I am not familiar with the regency but if you are able to change the polarity it should burn self shielding wire.
    Oswego IL
    743
    Default flux core
    If you are running self shielding wire yes u will need to run reverse polarity. Does not matter what machine u are using.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    Oct 2012
    14
    OK thanks, Yes i am able to switch polarity via the (+) and (-) cables .
    And yes to the I am using self sheilded wire.
