Results 1 to 7 of 7
    Dec 2012
    64
    Lightbulb Double Bench Grinder Stand
    Does anyone EVER update the projects gallery? The latest one in the SHOP section is several months old, at least.
    Anyway... I'm an amateur working out of my garage, so space is at a premium. I didn't have room to put 2 grinders on my bench, so I came up with this portable stand that I can use inside or out.
    The PREVious few pics show the construction, but it's nothing complex. I used a sheet of black vinyl (like a dealership's new-car license plate substitute) as a shim between the pipes. And there are diamond-tread rubber pads on the bottom so it doesn't move on pavement or wobble/slide in dirt. I've been using it infrequently for a few weeks now, and it seems to be very stable & convenient.
    Looks Good.
    Illinois
    644
    Nice, are those mounted in place or on receiver tube so you can place either one on top?
    That's a pretty cool idea....nice work.
    1,916
    It looks to me that you pull the pin & it rotates on the pipe so the grinders "switch places".
    Mar 2011
    st-eustache qc.canada
    259
    Thumbs up good job
    I made one last october, wanted it to swing away and the possibility to work from different positions, if your pic was posted yours before, i might have considered the portability feature of yours. Good idea.
    Dec 2012
    64
    Right - the table that they're both bolted to spins on the pipe. Flipping them also helps dump out debris that collects inside the guards.
