Almost positive that target in the video was set on the ground/against the bank. WRONG.
Target steel should be hung by two chains, so as to deflect upon impact. The sound at impact tells me they did NOT have that target set up properly (safely).
It's a good example of what not to do, thanks ja for posting it.
Also, anyone thinking of making a dueling tree should take a look at the high speed and $$$ newer commercial designs, which angle fwd, toward the shooter slightly, so that any misses into the frame, etc. are deflected downward.
Take a look at the Action Target brand. The only kind i will buy or suggest at present. You won't wear one out if used properly.
Results 11 to 13 of 13
Thread: welding 3/8" AR plate
01-10-2013, 09:42 PM #11
- Dec 2010
- Alaska/Oregon
- 27
01-11-2013, 04:34 PM #12
- Apr 2012
- 4
What type of fiberglass insulation would work best? Would fiberglass welding blankets suffice if I wrapped them up in it? Or do I need to look at something else? I've used fiberglass header wrap, and it isn't durable once it gets hot- will the same happen to the blankets? What about sand or other ways of controlling a slow cool down?
01-11-2013, 09:18 PM #13
- Apr 2009
- Oswego IL
- 513
ammo
Shooting the correct fragabile ammo helps to.
KevinXMT 304
Miller Spectrum 625
Miller 30a spool gun
S22a
Miller Legend 302
Lincoln LN25
