Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Dec 2010
    Alaska/Oregon
    27
    Quote Originally Posted by ja baudin View Post
    http://www.youtube.com/watch?v=1ShV7cii0aY
    This is what can happen when you shoot a steel target, scary!!
    Almost positive that target in the video was set on the ground/against the bank. WRONG.
    Target steel should be hung by two chains, so as to deflect upon impact. The sound at impact tells me they did NOT have that target set up properly (safely).
    It's a good example of what not to do, thanks ja for posting it.
    Also, anyone thinking of making a dueling tree should take a look at the high speed and $$$ newer commercial designs, which angle fwd, toward the shooter slightly, so that any misses into the frame, etc. are deflected downward.
    Take a look at the Action Target brand. The only kind i will buy or suggest at present. You won't wear one out if used properly.
    Apr 2012
    4
    Default welding 3/8" AR plate
    What type of fiberglass insulation would work best? Would fiberglass welding blankets suffice if I wrapped them up in it? Or do I need to look at something else? I've used fiberglass header wrap, and it isn't durable once it gets hot- will the same happen to the blankets? What about sand or other ways of controlling a slow cool down?
    Apr 2009
    Oswego IL
    721
    Default ammo
    Shooting the correct fragabile ammo helps to.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    Ford f450 Maintainer Srv Truck
