Results 1 to 10 of 13
    Apr 2012
    4
    Default welding 3/8" AR plate
    So I'm looking into making steel targets (spinners & gongs) and don't know how to weld AR 500 without ruining the plate from the heat. I'm using a diversion 180 and will have to make multiple passes to complete the weld so I was thinking I could make short welds and quench the part before the next pass. Or a wet rag etc to control the heat? I don't have any experience welding high carbon steel and could use some pointers. I've welded several pistol targets out of 3/8" mild steel but .223 tears it up and .308 destroys them. Any tips how to make them out of AR plate in my garage w/o ruining the steel with heat?
    Aug 2004
    Milan Michigan
    1,422
    I would preheat the 500 series and would not quench.
    Oct 2012
    12
    Friend of mine makes some targets. Preheat won't hurt but stuff welds like butter in my experience. Shouldn't have any trouble. I know he doesn't use any preheat when just making targets
    Apr 2012
    4
    It would be nice if I didn't have to preheat the ar 500, but I don't want to sell rifle targets that don't hold up. I may just have to weld one up w/o preheating and see how it handles a .308
    Apr 2012
    Western Pa.
    105
    Preheat will not hurt, it will only help & u will hv much higher success rate with heat.
    No big deal, just preheat to 500 area, weld, wrap in fiberglass insulation (cheap) cool slow, metal will retain all it's properties.
    Feb 2012
    Wa
    327
    Quenching and keeping the temps down are the exact opposite you want. Preheat and cool very slowly to let the piece normalize.
    Jan 2012
    Sierra Nevada
    37
    Default Safetys no accident
    Pre-heat to about 350.
    Be aware for ricochettes, .308 will go thru this **** as well as thru mild steel so don't kid yourself and .223 will definelty make some dings in that stuff as well.
    Problem is when you shoot this stuff it tends to send the bullet in directions that you didn't intend it to. So make sure the target is angled slightly towards the ground. Spinners are not cool.
    Know your target and whats beyond.
    Safe shooting
    Dec 2010
    Alaska/Oregon
    27
    Quote Originally Posted by Electric4Life View Post
    Problem is when you shoot this stuff it tends to send the bullet in directions that you didn't intend it to. So make sure the target is angled slightly towards the ground...
    Safe shooting
    Correct. Never forget that "Steel Shoots Back." The last commercial AR500 steel targets i purchased, included a warning to NOT shoot at the pistol targets within 25 yards, and NOT shoot the rifle targets inside of 100 yards.
    The usual issue is that a bullet can impact the target, turn inside out and come back up range at the shooter. Otherwise, there is frag from the bullet breaking up on impact, that will come back up range occasionally. Everyone must wear eye protection, even observers!
    Shooting steel, either a stationary "gong" at distance or a dueling tree up close, is a very good training tool, and more fun than punching paper. With some common sense and understanding of what is going on, it is relatively safe. Be prepared to occasionally pick a pc of bullet jacket material out of your cheek, if you don't heed the warnings above. Or worse.
    My sordid past includes a bit of blood, shed due to very dynamic use of steel targets. Consider carefully where and how you use them. Many public and even some private ranges, will not allow the use of steel targets due to all the above.
    Regret not being able to mfr my own steel targets but of late, i cannot source AR500 for less than the cost of buying a commercial target. There are no AR500 drops at my local suppliers.
    Apr 2012
    4
    A little common sense goes a long way. Now if I could sell common sense, I'd be a very rich man!
    Best advice for steel targets is to use non jacketed bullets. Much easier to do with pistol, but as long as you don't get too close, you won't get bit by a returning copper jacket.
    Mar 2011
    La
    174
    http://www.youtube.com/watch?v=1ShV7cii0aY
    This is what can happen when you shoot a steel target, scary!!
    Diversion 180
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Power Mig 180
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Shop full of tools
