    Aug 2012
    Hermiston Oregon
    127
    Default max'd out wire speed on 211. ?? help
    How could I turn up the wire speed on my welder while welding .030 aluminum
    On my spoolgun. I'm max'd out wire speed wise. But my amperage is at 4.5. While on 3/16".
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Wa
    327
    Can you run .035?
    Aug 2012
    Hermiston Oregon
    127
    Sure. But id still be lacking wire speed for proper bead flow for aluminum welding.
    Right?
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    6,765
    Nope, the bigger the wire, the slower the speed has to be, and for 3/16 you should be running 035 anyways.
    Wa
    327
    Yup what cruizer said. Beyond that you can buy a larger machine.
