I've heard of people making wood burners out of old propane bottles (small size) anyone made one got any pics etc... Or tips for making one?
Cori
Thread: propane bottle wood burner?
01-05-2013, 05:12 PM #1
- Jan 2013
- South Wales
- 5
If you ain't burnin' you ain't learnin'
01-06-2013, 09:12 AM #2
take a look at posts # 53 54 of this thread, may be not what you're looking for but anyhow some interesting pics.
http://weldingweb.com/showthread.php?t=60565&page=3
be carefull neutralizing these bottles properly...
good luck
01-06-2013, 10:24 AM #3
- Apr 2012
- Western Pa.
- 103
Now worth the risk!!!
Just get piece of pipe that size & weld cap or plate on end. No risk.
01-06-2013, 11:23 AM #4
- Oct 2011
- Minnesota
- 24
01-08-2013, 07:54 PM #5
- Dec 2007
- PA
- 287
cori_southwales
Here is a mailbox I made for an artist friend who wanted a unique mailbox as an easy way to find her studio and gallery.
Used a 20 lb propane tank as the body.
Have made about 8 to 10 of these "propane piggies" for friends as yard art.
My safery preparation procedure:
1 - Start with "empty" tanks.
2 - Use a special wrench I made to fit the valve. (looks sort of like a crows foot wrench)
3 - Use air powered impact wrench with 12" extension on the wrench.
4 - Submerge propane tank in 55 gallon drum full of water before removing valve.
( In case of sparks)
5 - With valve removed - fill tank with water, 4 table spoons of powdered dishwasher detergent and a squirt of liquid dishwashing detergent. Let it sit for 1-2 days, drain and repeat. This gets out the mercaptan additive (rotten egg) smell.
6 - After I have a " cleaned" tank, I still never cut or weld on it unless it is vented or has a big hole in it.
Don't want to end up on "America's #1 Idiot show"
Now I can cut off the handle and base ring and build the piggies.
Have fun but please be safe.
Thermal Arc GTSW400, Airco Heliwelder II, Miller Dynasty 350, Hypertherm 1000, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, etc.
