I have a syncrowave 180 sd, serial # leo50118. When I try to strike an ark it sounds as if it is very "straining" if you will then shuts down and sets a hlp 1 code. I have double checked all connections to the switch, even bypased the switch and problem still is there.
I called tech support and was told I have to start by replacing the board, no way to diagnose the problem just to change the board and see what happens. I feel there is a better way to diagnose this problem so I am here.
I was also told by an independent tech to just buy another machine. I apreciate any and all help I can get from you profesionals
Results 1 to 9 of 9
Thread: sorry, more 180 problems
01-05-2013, 12:46 PM #1
- Jan 2013
- 5
01-05-2013, 09:47 PM #2
One of your rectifier SCRs is cooked, should be replaced as a pair with #208384
01-06-2013, 11:34 AM #3
- Jan 2013
- 5
01-06-2013, 01:04 PM #4
Look in your book for mods 1 & 2
01-06-2013, 01:24 PM #5
- Jan 2013
- 5
Thank you again! Now is there any way to test these? Continuity, ohmeter ect?
01-06-2013, 01:35 PM #6
well, thats what help 1 basically means, and the problems you mentioned kinda verified it. What you can do is just take down the scr part# on the side of one of them and have a gander on ebay for better prices.
01-06-2013, 01:41 PM #7
- Jan 2013
- 5
The price from miller has been around 150ish, that doesn't scare me, I will replace both of them. However it is Sunday and I was board and have a dvom handy. Again thanks for your help
01-11-2013, 11:41 AM #8
- Jan 2013
- 5
Well I replaced the scr's at 367 bucks. Still have same problem, Any diag procedure I should try?
01-11-2013, 12:17 PM #9
- Dec 2012
- Sweetwater, TX
- 194
This YouTube video shows a pretty simple way to test them.
http://www.youtube.com/watch?v=S4To05OtDxs
