Results 1 to 10 of 14
    Jun 2012
    Alberta
    57
    Default Miller or Lincoln engine drive.
    Hey guys what's up, so i'm thinking i might get another portable welder if i can get on a certain job in a few months, i have a TB302 now and i love it makes me look like i can weld Lol, but i'm thinking of getting a diesel was thinking either a pipepro350 or a vantage 300-400, now i'm a Miller guy so i'm really leaning towards the pp350, but i want to keep my options open has anybody used either of these machines or both is there anything that would make me pick one over the other good or bad, i'm not looking to start a miller lincoln war, need help thank's guy's..
    Oct 2004
    Edmonton, Alberta
    8,230
    It's a toss up as both use the same technology, I'd go with the PP350 with the Mitsubishi engine, the Cat turbo, sounds powerfull, but in the real world not so much. Or the 325 is a fine mchine as well.
    Jun 2012
    Alberta
    57
    I like the miller cabinet and controls better they just seem neater, the 325 only comes with a gas engine will there it come with a diesel in the near future??
    Sep 2009
    Canada
    192
    As far as engine drives in diesel config goes, the Lincoln classic 300D would be my first choice for code work performance.
    Lincoln Idealarc 250 stick/tig
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Owner/Operator Devlin Metal Works
    Custom CNC Plasma Cutting and Welding
    May 2008
    Ashmont, Alberta
    36
    I'm a Lincoln fan and have the 400 Vantage and really like it but when it comes time to replace it I will be looking at the pipepro 350 because it is under 25HP so I'm thinking it shouldn't be affected by the new emission laws. I've welded beside the 350 and I don't think there is any difference between the two.
    I guess if you need 3 phase then go with the Lincoln. I think thats pretty much the only difference. The one I've been working beside has the Cat engine in it and it is quieter than the Perkins.
    Jun 2012
    Alberta
    57
    Would a Pro 300 compare with a Vantage or pp350?
    Oct 2004
    Edmonton, Alberta
    8,230
    No, no real comparison. The pp350/Vantage 300/400/500 use chopper technogy and are somewhat more technical to the pro 300
    Jun 2012
    Alberta
    57
    Do you know if there will be a 325 diesel Cruizer? and why would you pick the Mitsubishi over the Cat?
    Oct 2004
    Edmonton, Alberta
    8,230
    Its possible, to have a Diesel 325 in the near future, As for the Mit compared to the Cat. The can turbo has no jam compared to the mit.
    Jun 2012
    Alberta
    57
    Is it worth the extra cost of a Diesel for 400-500 hours a year or just stick with a TB325???
