I've been looking at magnetic grounding attachments for my new Millermatic as the clamps are inconvenient to use in many of my applications. Forney makes a 200 amp one for $35, while the 300 amp one is $55. Will 200 amps be enough for safe operation or do I need to spend the extra $20?
Thanks in advance.
Results 1 to 8 of 8
Hybrid View
01-04-2013, 10:00 PM #1
What size magnetic ground do I need for a Millermatic 211?
01-04-2013, 10:15 PM #2
- Nov 2012
- Northern Arizona
- 269
Do you run at max output all the time? That machine doesn't have a very high duty cycle at max output. I think the 200 amp clamp would be fine for your application.
I have never used a magnetic ground clamp. Just variations of the old spring clamp. Are they pretty neat?MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
01-05-2013, 07:22 AM #3
Magnetic clamp
I will not run this unit at max cycle very often. I like the idea of the magnetic clamp as you can place the ground near the weld in almost any configuration, which I don't think you can do with a regular spring clamp.
01-05-2013, 07:56 AM #4
I have a 200amp for my maxstar150 I recommend stepping up. I don't find the magnet to as strong as I want it to be and I have has issues where I will not have it attached 100% and it has gotten VERY HOT. If I was to do it again I would have gone with a 250amp clamp.
Never Satisfied
Millermatic 211
Maxstar 150STL
Metabos
Kennedy Maintenance Pro Full
Makita Cordless 18v Li-Ion
Stihl TS 420
Timfrank88@live.com
01-05-2013, 10:21 AM #5
- Jan 2013
- 1
Magnets aren't good, they mess with your weld, ground to table!
01-05-2013, 03:46 PM #6
- Oct 2006
- Illinois
- 459
here's a couple that we used at work.
http://www.amazon.com/Forney-58558-2...c+ground+clamp
http://www.weldfabulous.com/p-60900-...p-200-amp.aspx
http://www.weldfabulous.com/p-57934-...p-300-amp.aspx
01-05-2013, 07:14 PM #7
Member
- Nov 2010
- Central Kalifornia
- 63
Magnetic Ground
I have the three hundred magnetic ground. I have had problems with the ground staying on during times. If you weld next to thew ground it causes other problems for you. Really plays with the arc. Large flat areas are it's best use.
01-05-2013, 10:08 PM #8
- Oct 2007
- Cave Creek Az
- 797
You should pick the heaviest one, that way when it puts a big fat arc burn on your finished project you can throw it far enough away that it will no longer be in you sight! Biggest pieces of Cr%p ever made!
