Results 1 to 8 of 8
    Jan 2013
    near Industry, Texas
    7
    Default What size magnetic ground do I need for a Millermatic 211?
    I've been looking at magnetic grounding attachments for my new Millermatic as the clamps are inconvenient to use in many of my applications. Forney makes a 200 amp one for $35, while the 300 amp one is $55. Will 200 amps be enough for safe operation or do I need to spend the extra $20?
    Thanks in advance.
    Nov 2012
    Northern Arizona
    566
    Do you run at max output all the time? That machine doesn't have a very high duty cycle at max output. I think the 200 amp clamp would be fine for your application.
    I have never used a magnetic ground clamp. Just variations of the old spring clamp. Are they pretty neat?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Jan 2013
    7
    Default Magnetic clamp
    I will not run this unit at max cycle very often. I like the idea of the magnetic clamp as you can place the ground near the weld in almost any configuration, which I don't think you can do with a regular spring clamp.
    Jan 2012
    Metro Detroit, MI
    185
    I have a 200amp for my maxstar150 I recommend stepping up. I don't find the magnet to as strong as I want it to be and I have has issues where I will not have it attached 100% and it has gotten VERY HOT. If I was to do it again I would have gone with a 250amp clamp.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Magnets aren't good, they mess with your weld, ground to table!
    Illinois
    651
    Nov 2010
    Central Kalifornia
    64
    Default Magnetic Ground
    I have the three hundred magnetic ground. I have had problems with the ground staying on during times. If you weld next to thew ground it causes other problems for you. Really plays with the arc. Large flat areas are it's best use.
    Cave Creek Az
    1,081
    You should pick the heaviest one, that way when it puts a big fat arc burn on your finished project you can throw it far enough away that it will no longer be in you sight! Biggest pieces of Cr%p ever made!
