    Jan 2012
    Sierra Nevada
    47
    Default Portable gtaw ac/dc
    Is there a portable GTAW set-up that welds aluminum onsite, as consistantly as a Dynasty will in the shop?
    Oklahoma
    737
    Quote Originally Posted by Electric4Life View Post
    YES. The Dynasty 200.
    Griff
    561
    Are you saying a gas powered tig welder?
    The Dynasty 200DX is very portable. One day we may see a Dynasty 280.
    I use my Dynasty 200 and 350 in the field and power it with my 250 Bobcat and a 75' power cord
    Jan 2012
    Sierra Nevada
    47
    Lightbulb
    I'd like to clarify if the power delivery is smooth and consistant? I've used engine drives similar to the Bobcat 250 in the past with FCAW and it seemed to fluxuate a lot (no pun intended). I realize the two processes are very different however I am worried that while AC TIG welding that the inconsistant power supply could jeopordize arc stability and lead to poor quality.
    I use a Dynasty 700 daily, and it never occured to me that the smaller units would be suitable for onsite applications. Thank You for not raking me over the coals on that one
    561
    Some one will correct me if I'm wrong. I would think tig welding with an inverter based (auto line) welder would do better than a transformer type, using a power source like the bobcat 250.
    Wa
    656
    I agree with what's been said, powering a small dynasty through extension cords is probably your best bet. A small bottle of argon or having a dolly makes it that much easier.
