Results 1 to 3 of 3
    Dec 2011
    9
    Default feeder not feeding properly, Help?
    i have a 24A wire fededer that wont feed at the right speed. im not sure how to check the rheostat or the drive motor. or is there something else i should check, i have taken the covers off and blown everything out, inspected all boards vissually. it will feed with the rheostat turned almost all the way up, but very slowly.
    also is there a publication i can get for troubleshooting and repair of our machines. we are trying to do as much repair work in house now, im no idiot but not familiar with the inner workings of these machines. THANX for any help i can get. DUKE
    8,020
    Disconnect the guns trigger terminals and paper clip !&2, does the feeder work properly?
    Dec 2011
    9
    no it does not change reaction, it does the same with the feed/purge switch also.
