Just got asked to fix a crack in a transmission casing made of magnesium alloy (AZ91D). I have never welded magnesium of any kind. Will be using a diversion 165 with pure argon. I was hoping someone could give me some advice on filler material, and any tips or tricks you may know. Should I just prep it like aluminum? Any help appreciated.
Tyler
Results 1 to 10 of 12
Thread: Magnesium advice?
01-02-2013, 09:57 PM #1
- Oct 2012
- 10
Magnesium advice?
01-03-2013, 06:58 AM #2
- Oct 2007
- Cave Creek Az
- 797
" Will be using a diversion 165 with pure argon"
That is pretty questionable. There is just not enough amps in that unit to make that weld.
01-03-2013, 02:52 PM #3
I too would question whether a Diversion 165 will be capable of performing the weld adequately. However, depending on the location there might be enough power to provide sufficient penetration. You will want to clean the material much similar to aluminum:
- Degrease the base material with acetone, LPS ZeroTri, or rubbing alcohol.
- Remove surface oxides with a stainless steel wire brush.
- Degrease the base material again using methods in step 1.
- Joint prep (if applicable) should be done with a cutting process such as a rotary carbide tool or file (rather than a grinding/flap wheel process)
- Repeat steps 1-3 after any joint prep (if applicable)
- Preheating will help with puddle fluidity and can increase penetration - I would recommend using a dry heat such as a halogen lamp to introduce the heat into the case (improper use of a torch can lead to condensation, which in turn can cause porosity)
Using the appropriate filler material and adequate settings should produce good results.Andrew Pfaller
Product Manager / Welding Engineer
Miller Electric Mfg. Co.
01-03-2013, 04:33 PM #4
- Jul 2012
- 7
Let's look at Millers tig calculator http://www.millerwelds.com/resources...calculator.php
01-03-2013, 06:39 PM #5
- Oct 2012
- 10
Magnesium advice?
So assuming I have the power, is there a generic Mg filler rod I should use? Is 2% ceriated ok? Should I ball it or grind it to a point. I obviously have no experience with Mg but thought I won't learn without doing.
Thanks for the responses
Tyler
01-04-2013, 11:34 PM #6
- Oct 2012
- yuba city, CA
- 24
first time at Mg welding
If this is a repair that somebody's counting on....consider passing for all the good reasons you've already stated.
You need to match the filler to the casting makeup...which is ???
Run the ceriated with a point, for starters. Mg doesn't weld at all like AL, BTW.
At this point, you need to check on price and availability of possible
Mg fillers....sticker shock.
Either post pics of the crack and total casting or at least give description of where it is.
01-05-2013, 03:34 PM #7
- Dec 2009
- 44
I have never welded magnesium but Mr Tig has. I subscribe to his you-tube channel and he just posted a video just for you.
http://www.youtube.com/watch?v=ElT5qmUyagU
He is working on a brand new casting there so he isn't dealing with the oil in the metal. He also gives a link to where you can buy half pounds of magnesium filler.
01-05-2013, 10:27 PM #8
- Oct 2012
- 10
Magnesium advice?
I made it clear that this guy shouldn't count on this, but he had enough confidence to let me try (more than I have). Anyway thanks for all the advice. I'm sure either way I will learn a lot.
Tyler
01-06-2013, 12:39 AM #9
- Aug 2006
- Melbourne, Australia
- 100
Tyler you may get away with using your Diversion 165 as you don't need as many amps with Magnesium compared to Aluminium.
Use a die grinder with a coarse cutter and you'll find it doesn't clog up like Aluminium does to grind a groove where you need to weld.
Also use the die grinder to clean away the "skin" of the casting adjacent to the weld groove to ensure your weld area is clean.
The weld will be dirty there's no way around it but you have to be persistent especially with castings and if means grinding out welds till you get a reasonable run in the groove then that's what has to be done.
The weld will look smutty and dirty while your welding it but with a quick wire brush it comes up pretty good.
Because of your amperage limitations start on the thinner sections and weld towards the thicker sections to allow the heat to radiate and build up heat in the casting.
We weld Magnesium Sprintcar diff centres and it's often the quality of the casting that's the limiting factor, sometimes the casting won't weld regardless of what I try but I'm upfront in telling customers I don't know how a casting will weld until I actually start welding it.
For filler wire we use AZ92A, it's a pretty good all round Mag filler wire but be warned "it's expensive".
Don't use gas lenses, the cr@p thrown up by the arc will clog a gas lens pretty quick just use standard Tig collets and ceramics.
Hope this helps.
Regards Andrew from Oz.We are tig welders, gravity doesn't worry us.
OTC AVP300 AC/DC 300 amp hybrid wave Tig.
Kemppi MLS 2300 230amp AC/DC Tig for home with all the bells and whistles.
01-06-2013, 05:28 PM #10
4x4 gave you some good advise, But I'd like to add a few things.
4x4 you might want to try this the next time you get an oil soaked case.
If your dealing with a thinner section 3/16 or less dont vee groove, Use a stainless wire wheel on a die grinder to clean the top coating after you degrease, Then go over the crack with your tig torch with a few less amps than what you would typically weld it at ( Doing this will help pull the conatamination to the top )
Then use the wire wheel to clean the joint, repeat this process up to 3 times.
Then turn your amps back up, grab some rod and go at it.
Good luck.
