    Aug 2012
    Hermiston Oregon
    286
    Default quick connect ground on a Miller 211 ideas?
    I'm wanting to put a quick connection on my welder. Why because I'm always on the move. And its always in the way when it comes to storage. I like the ones found on thermalarcs or on the new multimatic 200. Any ideas. Advice. I'm eventually going to do it. But I am having trouble getting the female end with a sleeve to bolt on the front of my welder. If you know where I can locate one foward me the info.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Jul 2010
    Salem, NJ
    297
    I would just order a male and female dinse connector.
    It wouldn't be bolted to the machine, but your ground cable will just be 12" long when disconnected. If you really wanted it machine mounted, you can buy the machine dinse connector from your local welding supplier. It is a specialty item that usually only repair shops order.
    Jan 2012
    Metro Detroit, MI
    185
    Agree
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Aug 2012
    Hermiston Oregon
    286
    I did think of leaving a pigtail for the ground. But I think Itll look better if I had a dins type flush. But where would I get the housing? I've ask my local dealer. He couldn't help. Bull****. I think.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Cave Creek Az
    1,067
    Go look at the welders online on the miller site. Look up the part number for the one you like by finding it i the downloadable manual, then go to the Miller4less.com site and order it.
    Aug 2012
    Hermiston Oregon
    286
    Ok I'll give it a try
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    2,954
    Quote Originally Posted by eecervantes83 View Post
    Is this what you need?
    http://www.arc-zone.com/index.php?ma...649ltel56jf6b5
    Dec 2012
    64
    Question Slightly off-topic, but not really...
    Is there any power unit that has a receptacle for a spool gun ONLY, sized for a Spoolmate100? IOW: I want to buy a "replacement" receptacle withOUT a drive motor, but WITH gas feed O-rings, but I don't know what machine to look up a PN for, or if it even exists.
    Aug 2012
    Hermiston Oregon
    286
    Quote Originally Posted by Broccoli1:299029
    Looks right thanks
    I'll put in a order
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
