Need to cut 4 1/2" hole in 1/4" Aluminum backing plate for fighting chair.
Plate is secured to underside of floor deck of boat so it will be a 1/2" drill, not a drill press.
i only need to make 1 hole. Will a 4 1/2" Milwaukee hole saw work on Aluminum ?
or do I need a specialized bit ??
Thanks Ed
Results 1 to 10 of 12
Thread: Need 4 1/2" hole in Aluminum ??
01-02-2013, 09:50 AM #1
- Jan 2013
- 1
01-02-2013, 10:11 AM #2
- Apr 2009
- Upstate SC
- 129
Lacking proper tools, I'd just use a saber saw and a good metal blade for just one hole.
CGOld Miller Swinger 180 Buzzbox
Miller Diversion 165
Smithy Lathe/Mill
01-02-2013, 10:29 AM #3
- Apr 2012
- Western Pa.
- 103
Alm is soft, should work for one hole.
01-02-2013, 12:16 PM #4
- May 2012
- 21
I work on boats all day the only thing i find that will cut aluminum easy is a plasma. I do this all day and found that it is the right way to do this. Good luck
01-02-2013, 01:19 PM #5
- Feb 2012
- Wa
- 320
Just use the hole saw. I hole saw 1/4" steel all the time. Aluminum will be cake.
01-02-2013, 01:30 PM #6
- May 2011
- Bossier Parish La.
- 385
01-02-2013, 03:55 PM #7
- Oct 2006
- Illinois
- 459
I would use the hole saw too. If you want to keep the hole saw from wandering, drill the 4 1/2'' hole in a piece of plywood that will fit in your hole location. Cut the plywood so it is large enough to stand on. This will work as a guide and should work out well.
01-02-2013, 04:50 PM #8
Use something to help wash away the chips. Water soluble oil, Wd40, etc. even just plain water will help keep the hole saw from loading up. A drill with an extra handle is prefered so when it catches less chance of hurting your wrist.
01-02-2013, 05:20 PM #9
Hole saw
and lube the aluminum, you can even use tapping fluid, it will bind to the chips and remove them faster. Slow speed, you don't want to burn up your $5 hole saw
01-02-2013, 06:19 PM #10
- Oct 2007
- Cave Creek Az
- 796
Ditto the hole saw. A little lube and it will take less time than reading this thread.
