    Pittsburgh, PA
    74
    Default Oxygen tank question
    I have a brand new aluminum medical oxygen tank. It stands about ohh about 2 and half feet or so. Can this be used as a tank for an oxy/acetylene set up? I have other smaller oxygen tanks too they are only about 1 foot high or so maybe a bit more not even sure the diameter but I have 5 of them. BUt they are all aluminum green tops and bottom and aluminum color in the middle.
    I amTrying to figure out if I should try selling them off or keep them.
    Thanks in advance!
    Pat M
    Dec 2009
    Streamwood, IL
    87
    I have had 5 medical cylinders, size E, I believe, converted to both Oxygen, Argon, and Helium for portable welding.
    I went to a cylinder house in Aurora, IL to have this conversion performed. The cyls needed to be hydrotested, so it was a 1-stop shop.
    Having a portable Argon cylinder is really convenient.
    Happy new year!
    _kevin
    Syncrowave 250 Analogue
    Maxstar 200SD
    Maxtron 450
    IntelliTIG 40
    S64M Wirefeeder
    Non-Blue:
    Hypertherm PowerMax 1000G3
    Lincoln Precision Tig 275
    Lincoln WeldPak 155
    Pittsburgh, PA
    74
    Quote Originally Posted by karchiba View Post
    Happy new year!
    Awesome! Yep this is the E as well, brand new. One tank of oxygen went through it. I have 5 of the smaller ones too not sure what they are I will have to look.
    Thanks a bunch
    Happy New Year!
    1,880
    Depending how much you plan to use it these empty very quickly with cutting &/or heating.
    Pittsburgh, PA
    74
    Ya I can see that. I got a 125 cu ft tank for argon/co2 brand new. I was just curious. I will keep them around though. Not so much them real small ones but the Bigger one is alright and light, compared to the 125 cu ft.
    TY!
    HAPPY NEW YEAR!
Tags for this Thread
