Results 1 to 8 of 8
    Dec 2012
    4
    Default Miller Maxtron 450 cc/cv
    What's going on guys!
    I need some advice. Just bought a Miller Maxtron 450 cc/cv, and it was hooked up to 3 phase. How can I convert it to single phase?
    Cheers,
    8,097
    What is its serial#
    Dec 2012
    4
    I actually have 2 Miller Maxtron 450 cc/cv welders. Both are 3 Phase. Here are the serial numbers from both units.
    Serial No.
    Welder #1: KE640235
    Welder #2: KD512491
    Jun 2009
    Appleton, WI
    47
    You can connect those to single phase by connecting your incoming power to the "L1" and "L2" at the TE2 Terminal Block, where you connect your incoming power. Keep in mind the higher amount of primary current draw on single phase power.
    Input Voltage / Input Amps at Rated Output / Recom Fuse Size / Conductor Size
    230V - 89.6 A - 125 A - 4 ga
    460V - 47.2 A - 60 A - 8 ga
    Dec 2012
    4
    Thanks for the reply.
    My machine says 460/575v on the front panel.
    I need it to hook up to 240v single phase. Is this possible?
    My guess is 460v means single and 575v means three phase. I'm hoping I'm wrong.
    2,913
    Quote Originally Posted by MacGyver View Post
    Only if you have some way to step up the Voltage
    There is 460v Single phase as well as 575 single phase but that doesn't help you with trying to run it off of 240v Single phase since the machine you have was designed for 460v/575v Single or 3=Phase
    http://www.millerwelds.com/om/o2206d_mil.pdf
    8,097
    Well, 460 comes in singe or 3 pahse, as does 575. And neither are going to help your situation.
    you can get a step up transformer, somewhat costly. but it will work
    Dec 2012
    4
    Thanks for the help guys. Greatly appreciated.
