Results 1 to 3 of 3
    Oswego IL
    737
    Default xmt 304 as tig welder questions..
    When i bought my xmt it came with a complete tig setup. Torch with gas valve, foot pedal and the cups you would ever need. My big concern is the lift arc tig, i have always used hi frequency start. Is there any tricks to use it? I will be using it to weld in my cage in my firebird. Worse case
    I will borrow my buddies dynasty 200.
    Kevin
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
    8,172
    Its pretty easy, just put the tungsten on the work surface (no worries on contamination as there is no amperage there. then slowly lift the torch up, and off you go. Can't get much more simple
    Aug 2004
    Milan Michigan
    1,806
    Yup, I also agree, no need for a dynasty if you have a XMT.
