Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Default Problem solved.
    A friend suggested that I try a winch, looked at Tractor supply and they had one for $20 that has a 600Lb limit. It says for pulling not lifting but in this load will cause no problems. I am now in the thought process of making a bracket that will go onto the wall and then I can bolt on the winch at her shoulder height.
    Thank you for all for helping. My DIG camera has packed in, so was unable to post an image, third digital camera that has packed in on me. All my mechanical film cameras work as good as new. Miller should go into the Digital camera business.
    Happy New Year.
    Dec 2011
    230
    You may want to bulk up the drum on that winch some to speed up the lift. Winding on a 3/4" diameter or smaller drum is going to be slow. It will be a trade-off between effort and speed but you don't want your wife to get bored cranking that thing and hand the crank to you.-Meltedmetal
    Quote Originally Posted by Meltedmetal View Post
    Sir, you hit the nail on the head. It is only winding up about seven feet and if the drum has more diameter it will spool up quicker.
    It is excellent in that no effort is being used in raising the weight but as you said the number of cranks needs to be reduced.
    A Happy New Year too you and your family.
    James.
  4. #14
    Dec 2012
    Sweetwater, TX
    194
    Quote Originally Posted by jmpgino View Post
    I have a clothes pulley that has two metal frames, that five wooden rods go through. The metal frames are linked up with rope that go through two small pulleys screwed into the roof. The system is raised and lowered by the two ropes being joined together and tied around a hook.
    My question is as follows. My wife and even myself are finding it hard too raise and lower when wet washing is placed on the lines for drying. She does not even raise it up anymore, so I end up doing a limbo dance going under it.
    I have been looking for a low cost electrical system that would enable us to push a button, for raising it up and pushing another for lowering it. I was thinking of using a clothes dryer motor but have no idea of how to put the system in reverse, meaning up no problem but how do I get it down
    I understand this is not quite a welding project however it could well end up being part of one.
    A lot of you chaps work in all areas of manufacturing, so I thought your brains would help me...............I doubt when all fully loaded the whole system has more than 150 Lbs but my wife is only 107 Lbs soaking wet.
    So any help would be very kind of you.
    You could use a permanent magnet DC motor and use gears or pulleys to get the gear ratio right to handle the weight and up the torque.
    To reverse the system you simply flip the polarity going to the DC motor. Toggle switches (rated for the current your pulling) can work nicely. Or if you need more current I can draw you a schematic for a control using MOSFETs easily available at Radio shack. You can also google H-Bridge and that will be the MOSFET configuration you will need.
    I bought 3 DC permanent magnet motors off Ebay and paid about $30 each for them (several years ago). One is a 30Vdc and the other 2 were 50Vdc.
    Amtek made some that were VERY popular for people to use for small wind turbine applications (the reason I purchased these 3).
    The Amtek DC motors have since sky rocketed in price due to their popularity, but people also use treadmill motors as well.
    Wind enthusiasts typically are looking for low RPM (1800 or lower) / high AMPs permanent magnet DC motors because they produce the most power at low RPMs in the wind. But I find them useful for lots of applications since they provide lots of torque.
  5. #15
    Mar 2011
    st-eustache qc.canada
    106
    Smile Over kill
    Everyone here seems to get carried away on that...Come on guys it's only a clothes line.
    Electric motor, winches etc... will bring more danger and add more potent problems...(pinch points, entrapments, electrocution, kids etc...)
    Pictures are really needed here, from there may be some counter weight or additional pulleys or bigger pulleys.
    Unless the poster really wants it electric as a challenge for satisfaction i think it will be wiser to keep it as simple as possible.
    My respect to all posters, you most of the time by brainstorming get everyone to a higher level.
  6. #16
    Dec 2012
    Sweetwater, TX
    194
    Pictures would certainly explain a lot.
    The OP was inquiring about using a low cost electrical system and was thinking of using a clothes dryer motor so I was just trying to offer some suggestions in that area since I have experience in that area.
    Is this going to be something like a clothes line that moves the clothes along a cable?
  7. #17
    May 2011
    Bossier Parish La.
    385
    Quote Originally Posted by clint738 View Post
    He wants it to spin round and round to increase airflow over the clothes so they dry faster. Read post #8 problem solved. I still want to see pix of the set up.
  8. #18
    Dec 2012
    Simcoe Ontario
    47
    Default Help with small pulley hoist.
    Simplest way is use a 3-6 part line it will cut the weight in half every time it goes around the pulley no motors no electric hookup s. just pulleys and rope.
  9. #19
    May 2011
    Bossier Parish La.
    385
    Quote Originally Posted by Bistineau View Post
    Quote Originally Posted by Nathan128 View Post
    It's done already, just waiting for the pictures of the set up.
