A friend has let me use his Lincoln Tig 300/300 (the later model, not the old timer) to practice on at his shop and we are having a problem in that the green tungsten won't form a ball. Even he can't get a ball to form. It does weld, but not as smoothly as it should. The arc can go along fine then it becomes finicky and wanders (looks like arc blow in SMAW). I'm practicing on clean (3M Roloc polish pads) 1/8 aluminium with 3/32 Weldmark electrodes using straight Argon at 15 cfh. I'm on AC mid-range, current range 7, with start "ON" (constant). I have no idea what those setting translate to in amps. The torch is a Weldcraft water cooled with a #6 collet (no gas lens). The ground is solid. I think the problem is in the electrode but even if I switch to a new one the problem again develops. Any ideas? Thanx
Results 1 to 5 of 5
Thread: Tungsten Problem (?)
Hybrid View
12-30-2012, 01:01 PM #1
- Nov 2012
- West Central Mountains
- 21
12-30-2012, 01:38 PM #2
Your HF(spark switch?) should not be on start, it should be on AC continuous. The switch should have 3 positions, start, on, and continuous(AC).
I bet the points inside the machine are shot now too. I would clean and regap your points, then put the HF on the correct setting and have another go.
Good Luck.Last edited by shovelon; 12-30-2012 at 01:49 PM.
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
12-30-2012, 02:02 PM #3
I just pulled this manual and it is a bit confusing. I does mention something about failing PFC capacitors. You may want to have them checked.
http://www.lincolnelectric.com/asset...oln3/im349.pdfNothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
12-30-2012, 10:24 PM #4
- Nov 2012
- 21
Thanks for the quick responses. Pg 7 of the manual (IM349) says the "SPARK" switch should be set to "ON" for aluminium. I don't have the right equipment to check the capacitors and I know from my military experience that can be risky. Is that the case here?
12-31-2012, 07:16 AM #5
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
