    Nov 2012
    West Central Mountains
    21
    Default Tungsten Problem (?)
    A friend has let me use his Lincoln Tig 300/300 (the later model, not the old timer) to practice on at his shop and we are having a problem in that the green tungsten won't form a ball. Even he can't get a ball to form. It does weld, but not as smoothly as it should. The arc can go along fine then it becomes finicky and wanders (looks like arc blow in SMAW). I'm practicing on clean (3M Roloc polish pads) 1/8 aluminium with 3/32 Weldmark electrodes using straight Argon at 15 cfh. I'm on AC mid-range, current range 7, with start "ON" (constant). I have no idea what those setting translate to in amps. The torch is a Weldcraft water cooled with a #6 collet (no gas lens). The ground is solid. I think the problem is in the electrode but even if I switch to a new one the problem again develops. Any ideas? Thanx
    Aug 2010
    1,106
    Quote Originally Posted by idahoguy View Post
    Your HF(spark switch?) should not be on start, it should be on AC continuous. The switch should have 3 positions, start, on, and continuous(AC).
    I bet the points inside the machine are shot now too. I would clean and regap your points, then put the HF on the correct setting and have another go.
    Good Luck.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Aug 2010
    1,106
    I just pulled this manual and it is a bit confusing. I does mention something about failing PFC capacitors. You may want to have them checked.
    http://www.lincolnelectric.com/asset...oln3/im349.pdf
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Nov 2012
    21
    Thanks for the quick responses. Pg 7 of the manual (IM349) says the "SPARK" switch should be set to "ON" for aluminium. I don't have the right equipment to check the capacitors and I know from my military experience that can be risky. Is that the case here?
    Aug 2010
    1,106
    I believe it is rather simple. Like looking them over for damage and take a voltage reading with a volt/amp meter. But looking over the inside and blowing out is always a good idea.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
